05-30-2017 12:48 PM
Hello m3765.
Could you do a brand new forum entry for your inquiries ?
10-27-2017 01:52 AM
I can send the command like play, stop,shutdown to UR5 robot from LaVIEW to robot through TCP/IP control.Is there any other way to operate each and every axis of robot.and also want to get back current status of the robot into the LabVIEW program
10-04-2018 06:14 AM
Hi there
I intend to control UR5e with LabVIEW. I understand that the TCP/IP can be used for communication, but what drivers will I need to interface the two? Are there any libraries/drivers readily available? Also, If I need to develop the drivers, how do I go about doing it.
Thanks in advance
10-05-2018 10:59 AM
I'm unaware of any existing LabVIEW drivers for UR5e, but developing those drivers is no different than writing any other plug-and-play instrument driver. NI has a tutorial: http://www.ni.com/tutorial/3271/en/
10-08-2018 01:52 AM
Hi Seraph 1989
It seems you have used LabVIEW with the UR sim simulation software. Could you please help us with the same. We need to work with the virtual robot in URsim, controlling it with LabVIEW.
Thanks in advance
11-05-2018 02:35 AM
I am using UR10 for a robot project, can you please share the VI ?
My email address is kevin.rossi@lut.fi
And I have one question : how do you know which port you have to put ?
Kevin ROSSI
12-06-2018 12:29 AM
兄弟,你好,我现在也要用LABVIEW控制UR3和UR5,可否加个微信,请教一下,呵呵: 我的微信是:18623557787
01-15-2020 02:18 AM
Can I have your vi (I am struggling how to using sockettest to send dynamic data from UR10) thanks a lot
01-31-2020 01:00 AM
If your are looking for a quick way to communication and remote control your UR robot with TCP/IP, I suggest you to have a look at the UnderAutomation Universal Robots .NET SDK : https://underautomation.com
You can download it and reference the DLL in your LabVIEW project as described here : https://forums.ni.com/t5/Example-Prgras/Calling-NET-Assemblies-From-LabVIEW/ta-p/3496957
You can then get position, safety data, tcp information, io, ... but also send URScript, power on, load program, ...
02-01-2020 01:06 PM
Here is an example : https://underautomation.com/download/#labview-integration
