11-21-2008 01:18 PM
Hello All,
I am having some problems with the TCP-IP open VI.
When I connect my alptop over WIRED network, it works fine and talks to my board. When I put the Laptop on a Wireless network, it does not talk to the board. Can the TCP-IP open VI talk to the Wireless network ?
birapxi
11-21-2008 06:43 PM
Hi BIRA_PXI. We have used the tcp-ip open vi on wireless networks with no problems (LV 7.1.1, 8.2).
Are you able to ping the target when on the wired network? Have you tried disabling (not just disconnecting) the wired network?
We have seen situations where the wired network remained the 'preferred' network, even though it was disconnected,
preventing communication with some hosts on the wireless network. I would confirm pingability, then disable the wired,
reboot and try the wireless again. What version of LV and OS?
Matt
11-24-2008 11:48 AM
Hi Matt,
I am using Labview 8.5.1 and Windows XP, SP3. I was able to ping it over the wireless network, with the wired cable unplugged. I will try disabling the Wired connection and see if that works.
birapxi
