TDS5054B
I am using "Read(Multiple Waveforms".vi for TDS5054B but I get error message "Scan From String (arg 1) in tkdpo7k Fetch (Waveform).vi->tkdpo7k Read (Multiple Waveforms).vi->Untitled 1". What I need to check? Thanks.
(3,533 Views)
Hi PonTM,
check the incoming data connected to the "Scan From String" function. Which error number did you get?
Mike
(3,530 Views)
I use the sub VI which direct download from NI and the driver name is tkdpo7k. I get error code d85
(3,523 Views)
Hi PonTM,
the error description is clear. Are you sure you get some data?
Mike
(3,517 Views)
Accepted by PonTM
See here if you meant error 85
(3,514 Views)
