TURN ON ARRAY OF BUTTONS
How can I find one letter in a string and when I find this letter turn on a button. I mean, I have made an array of buttons and I insert one string (111222AABABB). Now I want to find if there are any "B" in my string and when I find one "B" I want to turn on automatically one button.
I start doing this program
Message 1 of 14
(5,106 Views)
'Match string' is a good function. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 14
(5,097 Views)
But I can´t connect the string and the array of buttons to the function you mention. Because the array of buttons is an indicator.
Message 3 of 14
(5,093 Views)
Make an array of Booleans, find the index (indices) of the character, replace the Boolean at those indices in the array of Booleans with a True, put the array in the indicator.
The last part (put the array in the indicator) can be done with a local write.
The first part (make an array of Booleans) can be replaced with a local read (if the indicator has the right size).
And alternative is to simply compare each letter in the string with the character in a for loop. Compare (Is Equal) and auto indexing will get you an array of true\false values. Put it in the indicator.
Message 4 of 14
(5,088 Views)
Thank you for your explanations, there have been very helpful. I think is easyer comparing each letter with a character in a for loop, But I don´t know how to do it. Can you help me please?
Sorry I don´t have to much experience in Labview
Message 5 of 14
(5,074 Views)
I have done this
Message 6 of 14
(5,067 Views)
Convert the long string to a byte array (String To Byte Array). Convert the character string to a byte array as well, and get the first element (Index Array).
No need for a loop (sorry about that), simply wire the array and the element to a Equal.
That is somewhat 'hacky' but very efficient.
In a for loop (what you have now) use String Subset to get individual characters. Wire the 'i' to the index and a length of 1.
I'd give both a try, that's a good way to learn!
Message 7 of 14
(5,062 Views)
BTW. In your VI "Array" is a control, not an indicator!
So either use a local to set the control value, or change it to an indicator.
Message 8 of 14
(5,055 Views)
you mean to do like this?
Message 9 of 14
(5,050 Views)
Accepted by topic author labview99
Getting there. It's simpler than you make it.
On the "B" string, converted to the array, get the first element (Index Array).
The result of the Equal is a Boolean array, so it will fit the Boolean array indicator.
Message 10 of 14
(5,042 Views)
