Take time between two max values
Hi people,
I have a problem and I have know idea how to solve...I need help.
The problem is that I want to take the time between two max values like in the graph you can see.
For example in the picture that I add
4,5 - 1,840 = 2,66
And put this value in the "Temps entre mostra".
This is that I want...
But this I think is very complicated because I don't know how to take the correctly time and do the substract...
thanks a lot,
Any solution?
Message 1 of 62
(5,412 Views)
Anyone?
Message 2 of 62
(5,358 Views)
Accepted by topic author jocuma
Hi jocuma,
I've tried something and hope that helps u.
Just created two arrays of temp and voltage. First i'll get the voltage value when it's more a certain value and of that same index get the time value and store in shift register.
When i get the second value higher than the threshold, I will get the time and subtract from previous value.
uday
Message 3 of 62
(5,347 Views)
Well,
temps = time no temperature..
I'm Catalan and maybe created some confuse things with the language Jaj...
Message 4 of 62
(5,338 Views)
Doesn't matter temps / time /tempearture, did u get the logic first??
In the example array i've provided, u should time = 1840-1770 = 70. which is what u need r8?
uday
Message 5 of 62
(5,336 Views)
Yes,
I tried something like this....now I'm...try to tested the results
Message 6 of 62
(5,334 Views)
It works but... for example
in the 17,990 - 17,910 =  0,08 or 18,010 - 18,000 = 0,010
this would be the correct time... :S
I dont know if I explain good what I want..
Message 7 of 62
(5,319 Views)
Yes, that's correct. for example, i've just taken some numbers. Good to know that it helped 🙂
uday
Message 8 of 62
(5,313 Views)
Uday it doesn't work good.
I pass my program ...It would be grateful if you can help me...
The program didn't substract good, because it substracts to 0 value and I want to substract the actual time from the last time...
Do you understand my problem?
srry for my english..
and thanks a lot,
Jocuma
Message 9 of 62
(5,253 Views)
Please find the modified vi in LV11 version and check if it works!!!
uday
Message 10 of 62
(5,232 Views)
