Take time between two max values
Message 21 of 62
(1,868 Views)
Took a little while, did it in brute force method (No optimization done, if u want u can).
I hope it'll help.
uday
Message 22 of 62
(1,862 Views)
Uday... I connect correctly good? because it doesn't work :S
Message 23 of 62
(1,852 Views)
In the first loop it was 7,4 instead of 4.5 isn't it?
uday
Message 24 of 62
(1,848 Views)
Yes but now I couldn't try...with 7,4 and I put a simulator with 4.5
Message 25 of 62
(1,847 Views)
Hi tood have you got de VI program please? it would be useful ...because I'll try faster if its works
thanks a lot 🙂
Message 26 of 62
(1,837 Views)
In the code i have written, you will get peak only when your value is greater than 7,4. Now the data is coming in the other way? Or you changed and want to try that?
In the third loop why are you initializing the array? Are you getting Time at Peak Indicator values properly?
uday
Message 27 of 62
(1,814 Views)
Yes i tried with other value not 7,4 but this is the good value. I have to incialize the array because the time comes from thee shift register and if i dont inicialize the array it appears an error dimension...
I tried other things and the diffenrence no appears in the table i couldnt understand...
Thanks uday
Message 28 of 62
(1,808 Views)
Hi...I don't know why in the table doesn't appear any number is very strange... i couldn't understand
Any solution?
thanks again....
Message 29 of 62
(1,779 Views)
Check without indexing or using for loop and get the time at that time. Will that give exact time?
I will explain what i have done there.
-Get the index in Voltage Array where peak happens.
-Using the same index get time value in the Time array.
-Once you get all the peak times, i am getting differences between them.
uday
Message 30 of 62
(1,765 Views)
