Take time between two max values
Here I put the new program... I did new things but if you open and see the indicator "element" doesn't appear nothing i couldn't understand
Message 31 of 62
(926 Views)
Hi jocuma,
can you try these things and let me know the output?
-Create an indicator after second for loop to get the indices/places where the peak occurs in amplitude.
-Please check the modified code and let me know if it works or not?
-Since i don't have hardware i am unable to simulate the data. So please provide screenshot or values of what you get next time in the indicators (Array,Time at peak all those)
uday
Message 32 of 62
(901 Views)
Hi Uday I think I find the problem but I couldn't solve it
I add the two screen shoots of where is and what happens...
In the array2 it doesn't work correctly
I add "prova1" modificated and the problem you can see in the pictures that I add
thanks a lot uday,
Message 33 of 62
(896 Views)
Here the result of the screenshoot of the array2 where is in the foorloop1
Message 34 of 62
(894 Views)
Did you try my new code, i didn't see that build array before firstloop1. why you added??
-And why build array for temps is 2d?? use only once.check my code again. and post the screenshots.
uday
Message 35 of 62
(890 Views)
I tried your code and it happens the same error like mine in the first loop I add the array2 like in the photos
this doesn't work because is 0 0 0 0 0 0 0
in your max_min program you sent it was 1 2 3 4 5
I think the problem is in the first loop.
Message 36 of 62
(879 Views)
Connect the Blue shift register from for loop to the outer while loop and make shift register and try.
-I think for every while loop iteration its causing/overwriting the values.
-Did you clear the extra build arrays??
uday
Message 37 of 62
(875 Views)
First I add a picture when I put the indicator where you want and the arrays always appears 000000 :S
Then the shift register I add is something like this?
Because if it's this has the same error :S
If you don't have the hardware You can use maybe the NI Max I'm using the USB-6009
thanks a lot uday!
Message 38 of 62
(865 Views)
You keep adding code when you should be removing code.
Message 39 of 62
(851 Views)
Hi tood first thanks for the help too,
Which I have to remove? because I think the problem is in the first for loop...if I put an indicator in there it appears always.. 0 0 0 0 and the other for loops if the one doesn't work the others too..
Have you got any solution? Is the for -loop only will run once? :S
thanks
Message 40 of 62
(847 Views)
