Take time between two max values
Forget about english 😛
-Are you getting data at Voltage and Temp indicators first?
-I think you changed the value to 4.xx instead of 7.4 isn't it?
uday
Message 51 of 62
(977 Views)
no :S
Yes because we changed something of the hardware an now the constant always is 4 and have the peaks of 5 or this but it doesn't matter about this...
Message 52 of 62
(976 Views)
Can you create indicator at "Dade" output and see if you can get any data first??
-Please tell me somewhere you're getting some data :P
uday
Message 53 of 62
(972 Views)
Uday i add a picture where is the data an where i didn't have maybe the problem is the conversion string to number ¿?¿? TT
Message 54 of 62
(970 Views)
First thanks for telling some where u';re getting data :P
-You need to Fract/exp string to number and then tell me if it works?
uday
Message 55 of 62
(965 Views)
Ok we progressed now the 2d temp and voltage have data but the time diff and time peak nothing :S
thanks uday
Message 56 of 62
(960 Views)
IT WOOOOOOOOOOOOOOOOOORKS FINALLY!!!!
thanks a lot UDAY!!!
Message 57 of 62
(956 Views)
You know what you should be jumping for going till that far 😛
-Now we deal with first for loop. Can you get some data before and after for loop?
-Can you show the 2d Temp and voltage values? Are you getting any values higher than 7,4 in that??
uday
Message 58 of 62
(955 Views)
Seriously???
I can't believe 🙂
Finally....
uday
Message 59 of 62
(950 Views)
It works Uday...I did what you say to use the fract/exp string and separate correctly an de difference is totally good!
thanks a lot!!!! 🙂
Message 60 of 62
(949 Views)
