‎03-06-2008 12:16 PM
‎03-11-2008 11:22 AM
‎03-11-2008 05:40 PM
‎03-12-2008 04:35 AM
‎11-11-2008 08:43 PM
‎11-11-2008 10:43 PM
‎11-12-2008 12:38 AM
yes i am using LabVIEW. Im using NI LabVIEW 8.20. sorry for not providing adequet information. The connection from my pc to the TDS 620A is GPIB-USB-HS. Im using Tektronix TDS620A oscilloscope. The scope is detected by Measurements and Automation perfectly. when i try to communicate there is an Error 6. I have never used older version for my communication. Is there any VI files that i can able to download so that i can control the settings of the scope using LabVIEW?
‎11-12-2008 08:48 AM
You should download the driver and install it in your instr.lib folder. You can search for drivers from the Tools menu in LabVIEW.
To learn what a driver is and how to use it, check out the main Instrument Driver Network page.
‎11-12-2008 09:58 PM
Dennis, thank you for helping. i solve the problem already. im now able to communicate with the scope through GPIB. Where can i find the VI so that i am able to obtain results of the waveform i acquire on the scope to be sent to LabVIEW. for example i have a sine wave signal and i want to compute the rise time fall time overshoot etc. is there any VI that is capable of obtaining it in LabVIEW???
‎11-13-2008 08:56 AM
Did you install the driver and are the functions available on your Instrument I/O>Instrument Driver palette? I haven't look at the driver myself but the task you want to do is pretty common and I would expect a driver function to perform a built-in measurement. There certainly must be at least a function to return a waveform.
