Temperature Based Compressor Control
Hi pjr1121, I do not intend anyone to provide me a fully functional vi. All I need is to understand the concept of that kind of controls. If someone sheds the light on it, I am sure that I can do it. Anyway, set points and rpm values are gathered from a simulation program not from an experiment. I will test the simulation program if I code this vi in an experiment.
Egemen
Message 11 of 17
(2,495 Views)
Revised with my original code it seems to work as requested.  On until reaches less than 0, turn off, wait until exceed 8, turn on, wait till less than 0, turn off.
Message 12 of 17
(2,491 Views)
Dude, you totally misunderstood the concept. Your code is not working as requested. I attached a graph result of the vi that I attached previously. Please check its result and your own results.
Egemen
Message 13 of 17
(2,483 Views)
The only difference I see here is that my code checks for LESS THAN ZERO.  You seem to want it at zero.  Just replace less than with a less than or equal.
Message 14 of 17
(2,475 Views)
Do we talk on the vi that you prepared? Your result is attached. I figured out it, but I typed previously about reverse fluctuations. Do you read about it? I also attached a result screen of reverse fluctuations. Anyway, thank you very much for your suggestions, I am so grateful.
Egemen
Message 15 of 17
(2,468 Views)
Accepted by newbieeng
Ya, as I said my code was for LESS than zero.  Since the data points only reached exactly zero, it didn't turn off.  Re-opening the vi I realized that I didn't save the changes I made to the raw data (i changed zeros to -1 for my test and this is why I thought your graph was from my code).
Here is the Corrected version with LESS THAN OR EQUAL.  No fluctuations in this one.
Message 16 of 17
(2,463 Views)
I did not recognize it. Thank you very much. It is proper now 😄
Egemen
Message 17 of 17
(2,455 Views)
