07-28-2021 01:28 AM - edited 07-28-2021 01:33 AM
Hi aaswil,
@aaswil wrote:
Where did you put the chart?
It's the item with the label "no label!". In your VI you deleted the label of that chart/graph, which is a no-go in my opinion…
@aaswil wrote:
Can you post your labview code?
I uploaded a snippet (read up that term in the LabVIEW help).
But I have/had problems when downloading the snippet as documented here. When you have the same problem please add a message in that thread…
07-28-2021 02:33 AM
wiebe@CARYA wrote:
Please embed images. Saves us a download, open and delete.
You might find this useful:
07-28-2021 03:27 AM - edited 07-28-2021 03:46 AM
Thanks. I'd try it if I used Firefox
I think I'll post it as an idea in the forum feedback forum. [EDIT I Bumped that post.] This should be standard.
07-28-2021 08:34 AM
Hi aaswil,
@aaswil wrote:
Can u help me?
I had a look on that new VI:
07-28-2021 08:14 PM
Hi GerdW
Regards.
07-28-2021 08:15 PM
Can you post the the code you made?
07-29-2021 01:20 AM
Hi aaswil,
@aaswil wrote:
- Why did you use a non-empty array constant to initialize the shift register holding the timestamp array? fixed
- The same applies for the array costant/shift register holding the measurement data… I thought I did as per your check1.png
Both are not fixed: the array constants used to initialize the shift registers still contain data/elements!
I cannot attach any code, I deleted the VIs after posting…
07-29-2021 06:31 AM
HI GerdW,
Here is my code, feel free to edit as necessary, and please post back.
Thank you very much in advance.
07-29-2021 07:06 AM - edited 07-29-2021 07:07 AM
Hi aaswil,
it's getting better… 🙂
See this:
07-29-2021 08:42 AM
Hi GerdW,
I'm amazed at how clean your codes are.
I still don't understand how the DAQ 9216 data will be represented graphically.
