11-30-2012 03:17 PM
are you still drawing Ray?
11-30-2012 03:23 PM - edited 11-30-2012 03:25 PM
got pulled away for a minute.. or 10...
ok... After the interruption 😉 I forgot if you wanted to stop the application AND close the front panel, so I put it in (at no extra cost).
See snippet below that you can put directly into your code. Grab the file and drop it on the block diagram.
EDIT: I live Jeff's solution as it does both..
I lost track of what it was that I was originally doing.. LOL!! Time to go home soon. Need a bit of wine..
well judging from my posts, maybe lots of wine.. That way I'll be able to whine.. 😉
I even forgot to put the image..
I realy need something.;..
I'm gonna call it a day... 😄
11-30-2012 03:27 PM
exe Ray exe...
Exit App instance not abort vi the vi will end just fine.
Did you start the weekend early?
11-30-2012 03:37 PM
D'Oh! 😮
I think my brain went on vacation right after lunch today...
Gives meaning to "being out to lunch", doesn't it? 😞
What the heck was I thinking.... Like I said, time to call it a day...
12-03-2012 08:28 AM
Hi all
Good morning,
I put the 'Quit Labview Function' in my program and generate a .exe application file.
After I close the application, the front panel is closed, but the the application Icon is still in the task bar of my 64-bit windows 7 computer. The Win 7 task manager shows 'not responding' . And after 52 seconds later, the application icon will be disappear.
Can anyone explain why the 64-bit Win 7 takes 52 seconds to close my application? It works fine in 32-bit Win 7 and XP.
BTW, the Labview is 32-bit 2011.
Steven
12-03-2012 08:32 AM
I've seen some similar behavior when closing programs (Word, DIAdem, TestStand, LabVIEW) with my 64-bit Windows 7 machine. I think it is the WOW (Windows On Windows emulator) taking time to close (and therefore keep the application in the icon). Maybe some IT scan is keeping it around a little longer?
12-03-2012 08:57 AM
Hi Crossrulz,
I think you are right. Is there anything we can do? 52 second is tool long for my application.
Thanks a lot.
Steven
12-03-2012 07:35 PM
I have a similar problem with exiting my project. The wait cursor shows for more than 30 seconds, then the project window finally goes away. This is just after opening it and then immediately closing it.
Win7 64 bit with LV2011SP1 32 bit
12-04-2012 04:54 PM
Did you try to check some steps commented in this forum in the previous posts? If you did, can you post a screenshot or explain how are you implementing your project?
12-04-2012 07:33 PM
Perhaps I should start another thread. My problem is with the development environment whilst the OP's issue is with a built application.
( I should get a kudo just for using "whilst")
