Thermocouple Measurement
I have a PXI 1031 Chassis that has a type 4060 DMM installed. I was
looking thru the LabVIEW VIs and found a couple that convert
measurements to temperature from thermocouple voltages. My question is
this: Do I need another card or other hardware to record temperature
measurements from a bare thermocouple, or can I do it with the DMM.
>From my understanding, all thermocouples are just dissimilar metals
that produce a small potential when heat is applied. Assuming I can get
the accuracy of voltage measurement (and low noise), are there examples
of DMM thermocouple readers in LabVIEW?
(2,997 Views)
You CAN directly connect the thermocouple to the DMM BUT
- you will have an implicit reference junction at room temperature, whatever that is
- you potentially can have errors if the temperatures of the two DMM terminals become different.
To read about reference junctions and get calibration tables see www.omega.com.
(2,984 Views)
Hello B-Rad.  You can build a really cool thermocouple measurement system by adding in a high power switch.  Please refer to http://zone.ni.com/devzone/cda/tut/p/id/3778#2 for more information.  This article has a ton of information about measuring thermocouples with a switch and DMM.
Brian
(2,938 Views)
