Thermocouple and Ultrasonic Sensor Code
Hi everyone, I am trying to read the data of thermocouple and ultrasonic sensor using VISA. I have made the code but I am unable to figure out that how labview will understand the data and display it one by one. I have attached my labview and arduino code. Let me know how should I optimize it.
(2,028 Views)
Can you provide a LV2019 version of your code?
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(2,011 Views)
Right now I am not using LV2019  but for reference i have attached the image to this reply. The temperature sensor is working fine but it's unable to read the ultrasonic sensor data.
(2,004 Views)
Accepted by topic author crabnebula
you can always save from a newer version to a previous version
https://www.ni.com/docs/en-US/bundle/labview/page/lvhowto/saving_for_the_previous_ve.html
in advance, i recommend you sending the whole message at once from arduino, not using several print functions. build a complete string, then send it through serial. Then in your LV code, use the "bytes at port" to check if serial is being received. then parse is in LV.
Sistema Fiep
CLAD, CLD
(1,999 Views)
(1,994 Views)
Thanks a lot, it really helped and not it is working.
(1,978 Views)
DON'T USE BYTES AT PORT!!
Please watch this video: VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(1,946 Views)
