Thermocouple measurement using cRIO
Hi  P@Anand
At start up I selected the Scan Interface (CompactRIO Scan Mode) programming model and not the LabVIEW FPGA Interface programming model, so I do not have an FPGA code when I expand the RIO chassis in my project. Thanks.
Message 11 of 14
(589 Views)
No its my mistake since I never worked with this chassis I was expecting a FPGA code. What is the data you are reading from the Shared variable?
Message 12 of 14
(588 Views)
HI P@Anand
I am not reading any data at all. Thanks
Message 13 of 14
(586 Views)
Can you try detecting the IO module once again from the Chassis?
Message 14 of 14
(583 Views)
