Tic Tac Toe Coding Challenge
Shane,
the good (and bad) thing about those challenges: If you start thinking about it, you hardly can stop the brain cells dancing with that theme...
Greetings from Germany
Henrik
LV since v3.1
Message 21 of 183
(5,763 Views)
Actually, I would allow a lookup table.  I think it would be challenging enough to generate the lookup table.  Of course, I won't take a 2 GB entry, or even a 100 MB entry.  The absolute limit would be around 10 MB, but I would prefer less than 1 or 2 MB.  So perhaps lookup tables won't be possible due to shear size.  Hmmm, perhaps that was another reason I picked a 4x4 grid.
Bruce
Bruce Ammons
Ammons Engineering
Message 22 of 183
(5,758 Views)
Bonus points for generating the look up table at run time Robot Very Happy
Double bonus points for a "general" solution for a nxn grid, where n>3.  Or maybe not.  As I look at my rough draft, it could easily be converted to a "general" loser. Robot surprised
Message 23 of 183
(5,742 Views)
@Bruce Ammons wrote:
I wrote one just for kicks, and discovered that the random player still won around 0.1%, which means my algorithm is flawed.
That could actually be a good way to resolve ties! Rank the entries with the same score according to the loosing percentage angainst the random player after a few million games. 😄
I also quickly made a very primitive player just for kicks (purely static evaluation), but it is not perfect. As X it still wins about 4 in a million (very reproducible after 10 million tries), while as O it wins about 5-7%. 😞 Is yours better than that playing as O?
Also make sure to test for legality in your tester (selected coordinates don't yet contain a piece AND are in the range 0..3) and immediately disqualify flawed entries. 😉
Message 24 of 183
(5,724 Views)
I'm just reading this thread for now... and being entertained 😉
Not to modify the contest, but an interesting challenge would be the ability to play Tic-tac-toe to win, by having people's code play against one another.  That way whoever actually wins most often and fastest (less time) actually wins..
Just throwing a silly idea...
Ray
Message 25 of 183
(5,718 Views)
Hey, I did a 20 second modification to my draft and simply inverted the evaluation function. Result (Win%, loose%,draw%) against the randomizer:
As X: [29%, 0%(!), 71%]
As O: [22.5%, 0.01%, 77.5%%]
Beat that!
Interestingly, against itself it is a 100% draw...
Message 26 of 183
(5,690 Views)
I thought that was one of the "features" of tic-tac-toe.  If both players play to win, it will always tie.  I would expect it to be doubly true if both players are using the same algorythm.
Message 27 of 183
(5,685 Views)
jasonhill wroteI would expect it to be doubly true if both players are using the same algorythm.
Now that would interesting to try out 😉
Message 28 of 183
(5,673 Views)
The original idea for the challenge was to play to win.  I decided it was too easy to write an algorithm that would never lose.  I wrote one in a just an hour or two that I think worked pretty well.  That is why we decided to make you try to lose instead of win.  This appears to be more challenging.
For my current solution (discussed earlier), I just inverted the logic on my winning routine.  I found out that it would still win against the random player occasionally, where I expected it to always be a draw or loss.  I figure there has to be a better algorithm that will never win, but I haven't figured it out yet, and I can't prove that it exists.
For the competition, I will have each player play every other entry, once as X and once as O.  The player with the most losses and draws will win, where a loss is 2 points and a draw is 1 point.
If you haven't read the rules on the LabVIEW Zone, please do so.  There are a lot more details provided there than on this discussion.
By the way, Mike Teixeira gets a brownie point for submitting the first entry in the contest.  As soon as I get a few more entries, I will be able to post some preliminary standings...
Bruce
Bruce Ammons
Ammons Engineering
Message 29 of 183
(5,671 Views)
It seems that it is easy to fully analyze the problem and make a god-like program that fits in a few MB. This is similar to the fully analyzed chess endgame databases originally started by Ken Thompson many years ago.
Removing all symmetry related positions, all illegal positions (number of X=number of O or O+1) and everything with more than two rows of four, there is not much left, for example there are only three unique moves to start the game.
I wrote a quick a dirty program to generate all possible legal positions (takes only a few minutes). now it would be easy to recursively create a scoring table to produce a (win in t, loose in t or draw) to every possible case. Attached in a graph of the number of unique positions as a function of the number of pieces on the board. Anyone got a similar result?
Message Edited by altenbach on 05-01-2006 01:26 PM
Message 30 of 183
(5,607 Views)
