Tick count
How to make a an indicator turn on after 15 seconds using the tick count?
Message 1 of 17
(6,314 Views)
well here's some pseudo code which might help
if (current_tickcount - starting_tickcount >= 15000) then turn_on_indicator
you'll just need to deal with the case where tick count wraps around (one way of doing this is not to use tick count at all)
Message 2 of 17
(6,302 Views)
Here. Let me know if you need any explanation
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 17
(6,283 Views)
I have the 10.0 version of labview and it is not possible to read the sent VI. Please help.
Message 4 of 17
(6,278 Views)
Here
--Ranjeet
Message 5 of 17
(6,273 Views)
The problem is that the indicator is not turning on after 15 seconds
Message 6 of 17
(6,267 Views)
Here for testing puspose I made it for 5 sec.Now I changed..
Now try
--Ranjeet
Message 7 of 17
(6,264 Views)
can you please convert it so i can read on my 10.0 version?
Message 8 of 17
(6,260 Views)
Accepted by Majd.n96
Oops
--Ranjeet
Message 9 of 17
(6,257 Views)
although it did not work, i would like to know the logic behind it.
Message 10 of 17
(6,253 Views)
