Time Delay between two parallel while loops
It is not in sequence. Its will generate parallel with 15 seconds delay.
Message 11 of 16
(2,141 Views)
i guess we misunderstood you,
so what i now gather is, that you want to start the first loop, which will still run while the second loop starts, and so forth
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 12 of 16
(2,134 Views)
Thank You.. This logic works.
But when running multiple while loops the graph is not generating properly. It seems to have some data loss. Cold You please go through below attachment.
Message 13 of 16
(2,106 Views)
have a look at the VI Properties "Execution" of your "Profile Run",
which is atm in Non-Reentrant mode.
i suppose it needs to be preallocated-cloned-reentrant to work correctly.
Message 14 of 16
(2,067 Views)
Accepted by $agar
1: if this will be the same for all loops, just declare it once and wire into the other loops from here
2: the server reference links to the same control, therefore the value will be the same
3: why do you need a feedback node here? this is a subvi, that will be called on each loop iteration, and all values should be given by the normal terminals (i am not sure what the feedback node retains -- if anything -- between loop itereations)
4: you will most times get negative values, because the get-time after the case structure will be executed most times before the one in the case structure
Message 15 of 16
(2,064 Views)
Thank You..It work.
Smiley HappySmiley Happy
Message 16 of 16
(2,035 Views)
