Timing delay after an even before taking a reading
Hello all,
I am working on a research project where we need to change the temperature of a device and then wait between 25 and 30 ms before starting a periodic A/D sampling loop.   Now my question is how do I accurately sample some time after a given event?  Also how do I get a timestamp on samples in relation to a given event?
For hardware we have measurement computing PCI-DAS6071 and PCI-DAC6703
Thank you in advance for your time and help.
Sam
(2,943 Views)
Hey,
You could use an Start Trigger to start your acquisition, then it is possible to delay the acquisition after the Trigger occured using the following property:
Trigger Delay
Message Edited by Christian_M on 01-08-2008 09:23 AM
(2,940 Views)
Interesting,  those blocks look unfamiliar to me.  Will they work with measurement computing boards as well as NI boards?   I think that is where I am having the greatest deal of difficulty is not knowing which group to ask 🙂
Thanks!
(2,937 Views)
This are DAQmx VIs...., and they are working with NI Boards, like the PCI-6071 you mentioned.
(2,932 Views)
Hi Swinchen,
The block that you probably do not recgonize is a DAQmx Trigger Property Node.  You can find it in the Measurement I/O >> NI-DAQmx >> Triggering Node.
Hopefully this will get you started.
Thank You,
Nick F.
Applications Engineer
(2,899 Views)
