Top level vi or subvi?
that's probably a question that has been asked a thousand times already but nevertheless I haven't found an answer in the forum yet.
In the code of a vi I need to know whether the vi was started manually as a toplevel vi or whether it was loaded as a subvi or dynamically as a plugin. I need this information to build a path dependent on the run-type of the vi. Where do I get this information from?
Peter
(2,646 Views)
Do you know "call chain.vi"?
try it and give me some news.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,634 Views)
Jorge,
thank you. Yes, I already knew the vi "call chain". However, I thought there would be something more elegant. Right now I don't have the time to penetrate the problem in depth. Maybe I'll come back to it later.
Peter
(2,595 Views)
Hi there.
Try placing af prperty node with class: Vi Server.VI and use the Execution.State property.....
It will tell wether the VI is called from another, or its the top level.
Message Edited by BCL@Servodan on 06-11-2008 07:38 AM
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(2,592 Views)
