Transparency in histogram bars
is there any chance to make transparent (a percentage) the bars of an histogram graph.
Attached an example. This is very useful when you have 2 populations which are superimposed. Otherwise, one completely cover the other.
Thank you.
(3,094 Views)
-Wire the Plot Color Property node of the graph to Color Box Constant or the value along with RGB and Transparency in the below link:
http://digital.ni.com/public.nsf/allkb/B61D723CC7B7BE4E862568F8004C3ACB
uday
(3,079 Views)
Hello logatto,
Have you found a solution to this problem?
Thank you.
(964 Views)
