Transpose 1D Array
And why not????
Just look at the detailed help for the darned thing
Message 11 of 32
(3,681 Views)
Since it seems part of LabVIEW, it probably does something, such as adding an internal tag to the data. (similarly, remember that the compiler not always transposes a 2D array if requested during computations, but just tags it to have the indices swapped, and e.g. be autoindexed first by columns, etc. in order to avoid an expensive transpose operation if it is not really needed).
Do you know where this VI is located in the LabVIEW distribution? My guess is that it could have something to do with Mathscript, since the matlab syntax does make a distinction between row and column vectors, while native LabVIEW does not. So I could imagine that it is used in some of the linear algebra there.
Of course I am wildly guessing here an could be completely wrong 😄
Message 12 of 32
(3,673 Views)
aputman
Message 13 of 32
(3,668 Views)
@aputman wrote:
This is a standard matrix function and probably has little to do with this discussion.
Message 14 of 32
(3,659 Views)
@altenbach wrote:
....Yes but it is also a linear algebra function, as you mention above.
aputman
Message 15 of 32
(3,656 Views)
@aputman wrote:
If the one posted by Paul is a linear algebra function for Mathscript that does the same operation (at least on a 1D matrix) as the Transpose Matrix, why are there two VI's that do the same thing?  Why is it called (or labeled by Paul) as Transpose 1D Array, when we all know that has no meaning?  I don't have access to 2016 to see where this came from so is Paul trolling us or is this a troll by NI?  Does the VI output the same array as the input (meaning it does nothing....has no meaning)?
aputman
Message 16 of 32
(3,643 Views)
@jwscs wrote:
but what is this endeavor about? i'm curious.
I ran across it, and couldn't resist tossing it out just for fun.
Obviously it takes a vertical 1D array and converts it to s horizontal 1D array.  (But what if I want to go the other way?)
Message 17 of 32
(3,638 Views)
@Ben_Manthey wrote:
These days 'Trans Rights' are all the rage. Make sure you ask it what pronouns it prefers.
If my employer ever asks me what pronoun I prefer, I'll answer: "His most supreme excellence, the imperial Grand Poobah of the entire North American continent" (after all, I can 'prefer' anything I want).
Message 18 of 32
(3,634 Views)
@altenbach wrote:
It doesn't take a matrix as input, only a 1D array.
Message 19 of 32
(3,630 Views)
It's a real built-in LabVIEW function.  The output is the same as the input.  I can't imagine why it's there (except to give us something silly to talk about).
Message 20 of 32
(3,628 Views)
