Trouble with Writing to spreadsheet file
Hi there, I encountered some problem while trying to write to a spreadsheet file. But when I tried to open the file, nothing was written there. Would appreciate your help,thanks.Untitled.png
Message 1 of 16
(4,212 Views)
Share Actual Vi/Snippet instead of Image.
 Did you got any error?
Are you sure data is being generated before writing to a file (can probe and check)
Message 2 of 16
(4,208 Views)
Hi, sorry about that. Here's the VI.
Message 3 of 16
(4,204 Views)
To be sure that you are writing some data to file, check by keeping an indicator/probe to the array input.
- Also make sure the file path is correct and you have read/write permission to that file.
uday
Message 4 of 16
(4,202 Views)
I checked piece of your code by feeding inputs of my own, it works fine.
Make sure about your data, whether any data is being transfered to input node of Spreadsheet VI.
Message 5 of 16
(4,181 Views)
Now that I tried creating a new file in a new location and there's this pop-out. However, I'm sure that I've saved it to the correct location.
Message 6 of 16
(4,175 Views)
As suggested in error description just copy the file path and paste in file explorer or in run command and check if the file path is correct.
-One more easier method is right click on path constant browse for path and point to file.
uday
Message 7 of 16
(4,169 Views)
You dont need to create a file, Write to spreadsheet file will create new file by default, if the file is not present
Message 8 of 16
(4,160 Views)
where exactly do you have your VI running? Which target system do you use?
Is it by any chance a RT target (like cRIO, myRIO)? You know those are "stand alone" computers on their own with NO access to your PCs harddrive?
Message 9 of 16
(4,158 Views)
Hi PalanivelT, I've tried all the suggestions, everything seems fine, but, still not able to read into spreadsheet file. I've also tried changing my input data to random number, still nothing is write in.
Message 10 of 16
(4,153 Views)
