Trying to Export Waveform Chart to Excel
Why do I get this error?
Message 1 of 8
(3,133 Views)
Hi!
Can you show also the relevant part of your code, please?
Marco
Message 2 of 8
(3,117 Views)
Hi August,
from your picture it seems you're trying to save a file on your PCs harddisc while running a VI on a realtime target (conclusion from error message mentioning "Real Time Interface" and different path formatting).
You can't save a file from your target to a different PCs harddisc!!! You have to create that file on a local storage (using proper file paths) or use network access to transport data (like shared variables) to your PC...
Message 3 of 8
(3,115 Views)
I see, because my program is running in real-time. So if I want to save in my PC, I need to create a VI in computer right? Does simply calling the VI from the computer in the Real-Time VI fixes this problem?
Message 4 of 8
(3,103 Views)
Hi august,
to repeat my message: You can't save a file from your target to a different PCs harddisc!!!
Your VI runs on the target, even when you watch it running on your monitor. Just look at the left down corner of the VI's frontpanel:
Here LabVIEW tells you where the VI is running. In the shown picture the VI belongs to a project and is running on a target named "Demo-Fzg" (which is a cRIO)...
Message 5 of 8
(3,096 Views)
So the only way to save the data is by right clicking the waveform chart and export as Excel?
Message 6 of 8
(3,090 Views)
Hi august,
to repeat my message: You have to create that file on a local storage (using proper file paths) or use network access to transport data (like shared variables) to your PC...
LabVIEW comes with a lot of examples. Did you check them?
LabVIEW comes with some predefined projects. Some include host ("PC") and target ("RT cRIO") applications like yours. Did you check them?
You always have the option to transfer data from target to host. Use them to automatically create files on your host's harddisc!
Message 7 of 8
(3,087 Views)
Great, thanks for the input
Message 8 of 8
(3,078 Views)
