Showing results forĀ
Search instead forĀ
Did you mean:Ā
Two Operations is a Loop
I need to Perform two Opreations one by one for a Particular no. of times.
Ex: register write operations need to perform, data is from a table of two columns and no .of rows depends on runtime only.
How shall i implement this?
Please comment on this.
-mfp.
Message 1 of 8
(4,250 Views)
"I need to Perform two Opreations one by one for a Particular no. of times"
You can use sequence.
or
state machine architecture.
but I am not clear about your post so kindly please alobarate what u want?
thanks
CLAD
Labiew programmer
Message 2 of 8
(4,236 Views)
Okay.
I shall use Sequence structure for two operations to perform sequentially.
Each of the set of operations in the sequence required data from a table.Table contains two columns one is I/O Address and the other is Data, so that i need to write a Data to Corresponding I/O Address one by one, that means one operation is for Writing I/O Address and the other is for writing Data. The sequence has to take these I/O Address and Data from the table and perform the operation one by one. User can change the no. of sets of operation.
-mfp.
Message 3 of 8
(4,231 Views)
For Loop.  Have the table autoindex on the tunnel of the for loop.  Then break the resulting 1-D array inside the loop using Index array to do your two writes sequentially.
Message 4 of 8
(4,224 Views)
Thank you very much for the reply.
Could you please share me a sample VI using the above concept.
-mfp.
Message 5 of 8
(4,202 Views)
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 6 of 8
(4,191 Views)
Sorry, I couldnot able to crack the issue.
Anybody Please help a bit more to get it solved.
-mfp.
Message 7 of 8
(4,161 Views)
Hi Favas,
do it like this:
18611i0B990E102CACAC32
Those two file functions just represent your two operations. They are sequenced by the error cluster - the preferred way to do so (no sequences needed!).
Message 8 of 8
(4,154 Views)
