Two equal consecutive integers
In this vi if 2 consecutive numbers are equal the boolean remains true while it should turn off then on.
If there a way without using local variables to do that?
Message 1 of 32
(5,417 Views)
You use shift registers to avoid using local variables.
Since you are dealing with integers, all of your wires should be blue rather than orange.  You can run into problems trying to compare whether floating point numbers (orange) are equal to each other.
You can also use the Quotion remainder function instead of division and rounding down.  That will guarantee you have an integer and is also fewer operations.
Message 2 of 32
(5,412 Views)
Accepted by A.A.A.
After writing each boolean, you need to clear it before going to the next iteration. This is most easily done with an inner FOR loop containing two iterations.
Here's a quick draft. See if it works for you.
(I also simplified the rest of your code, wich was exceedingly convoluted. I am sure it could be simplified further. Note that I used a transparent cluster for the LEDs, eliminating all these comparisons)
Message 3 of 32
(5,399 Views)
altenbach! very nice idea !Ill do my own vi and posted later.
Message 4 of 32
(5,367 Views)
I have tried do it but I am getting an error :connected a cluster of 9 contents and a cluster Cluster of 10 elements.
Message 5 of 32
(5,340 Views)
Did you try a search? This question has been asked before many times. Did you try the LabVIEW Help? Be honest here. The LabVIEW Help would have told you that the Array to Cluster function defaults to 9. You have to right-click on it and set to the number of elements you want.
Message 6 of 32
(5,330 Views)
Message 7 of 32
(5,322 Views)
I used the help but not on the Array to cluster function but on the Cluster 😕
I'm fixing the vi now.
thanks
Message 8 of 32
(5,318 Views)
The first element of the constant array missed a zero.
This is the final VI.
Message 9 of 32
(5,311 Views)
In addition to Saverio's advice, here are a few more comments:
  • Don't wire N if you are autoindexing. The loop count is fully determined by the array size of the autoindexing array, so don't over-determine the code. If you do, you need to do multiple modifications to change the program.
  • Since the ID input has 9 digits, use a format of %09d to display all leading zeroes. (if the possibility exists that longer numbers are entered, you should also set input limits)
  • For small array diagram constant, I would always show the first out of range element so it is clear how big the array really is. If you don't, it could be much longer than the display. (For large array diagram constants, simply show the scrollbar).
  • Your case structure has a wait primitive in each case, thus the wait belongs outside the case structure. Don't duplicate code! (I would avoid the case structure and autoindex over an array of waits.)
  • The first two numbers in your array constant are identical. Probably a mistake (Ah, you fixed that!). (It might be better to calculate the values from first principles based on the iteration terminal. Won't be that hard (not shown).
  • You could also use a feedback node.
Message 10 of 32
(5,308 Views)
