Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
UDP address!
UDP address!
Atmapuri
Member
03-15-2004
08:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi!
The UDPWrite vi expects the address of the computer and the type is U32.
But the address is usually www.something.com or an IP address.
So what is U32 and how do I get it from an IP number?
Thanks!
Atmapuri.
0
Kudos
Message
1
of 2
(2,984 Views)
Reply
Re: UDP address!
Shan
Active Participant
03-15-2004
12:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Check out the shipping example "UDP Sender.vi". It can be found in \examples\comm\udp.llb or search the help for udp.
Basically it uses the "string to ip" function so you can input your IP in XXX.XXX.XXX.XXX format
Tim
1
Kudo
Message
2
of 2
(2,984 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
