UDP data format
What do you mean by have the Current Data indicator show typical data? It's just an FYI to show what line of data labview is reading.
Here is the data that should be read in by labview though.
Message Edited by mattbiegner22 on 06-13-2010 06:28 PM
Message 11 of 16
(3,042 Views)
I just need to see how a typical string looks like. If you want, just copy/paste a few lines from the datafile here.
EDIT: OK, got it. Thanks!
Message Edited by altenbach on 06-13-2010 04:31 PM
Message 12 of 16
(3,037 Views)
-117.857338,34.899256,669.580733,0,0,0
-117.857338,34.899256,669.580734,0,0,0
Message 13 of 16
(3,033 Views)
Accepted by mattbiegner22
Here's what I would do instead (LabVIEW 8.6).
Message 14 of 16
(3,009 Views)
so is the typecast block converting it to binary data by default?
Message 15 of 16
(2,987 Views)
Yes, if you don't wire the type input, you'll get a string.
Message 16 of 16
(2,983 Views)
