UI design
     As we all known that the UI is often the “cover” to our book –the crucial first impression. But  how to design an excellent UI really bothers me. So here, I want to ask are there some good books , BBS or  Blogs providing the UI design skills and examples??Please recommend toUI  me if you know,  thank you for your help.
Message 1 of 16
(5,927 Views)
A discussion was recently started here. Good information to start.
PaulG.
Retired
Message 2 of 16
(5,920 Views)
UI Interest Group has also interesting information and examples
Message 3 of 16
(5,866 Views)
I doubt you will get perfect answer from anywhere becasue requirement varies from person to person. You definately will get reference
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 16
(5,836 Views)
Thank you. I have read all the documents on the UI Interest Group.  I think it's helpful.
Message 5 of 16
(5,821 Views)
          I have read the information of the discussion, It's helpful. But what I really need is some Measurement and Control UI design documents. Do you have some to recommend?
        I must say sorry to all of you that I didn't express my need clearly.
Message 6 of 16
(5,811 Views)
What is your requirement actually? What you measuring and controlling. I will try to share the doc accordingly.
Also check in forum, you will get something helpful
--Ranjeet
Message 7 of 16
(5,803 Views)
    I am now programming a DAQ sysytem. I have nearly finished  the functions including acquisition, storage, processing and display.  But I really have no idea how to design an excellent UI which is so important  to a  program.
Message 8 of 16
(5,795 Views)
A Start button and an aquisition graph is all you need. Settings and stuff should be menu options.
If the display of the processing requires showing you can use a 2-slot tab control with the actiosition on one and the result on the other.
Keep it as simple as possible.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 16
(5,771 Views)
Also, small things like coloring indicators can do alot, bit keep it subtle.
Qestit Systems
Message 10 of 16
(5,788 Views)
