.exe file does not work on another computer
Hi all,
Recently i have ceated LabVIEW application from .vi to .exe file.
I tried to open this application on my computer with LabVIEW installed, it's working perfectly fine, but when i copied this file to another computer, which does not have LabVIEW installed, it didn't work properly.
By work properly, i mean the application can be opened but the data monitoring part is always showing zero, which is not true, seems like this application does not connect to the sensors at all.
Any suggestions?
Thank you in advance,
Thanya
Message 1 of 11
(6,483 Views)
first :
you can't just copy the .exe file on another computer if labview isn't installed, you must use an installer that include your .exe
 Moreover :
Do you have some drivers that are not installed on the other computer ?
your sensors have the same COMPORTS as your computer ?
If you launch a VI with property nodes, you should include them in dependancies : beware of the loading path in the code, it changes when you use an .exe
Regards
Message 2 of 11
(6,470 Views)
Did you install the necessary drivers on the other computer?  What are you monitoring?
Message 3 of 11
(6,464 Views)
I'm not quite sure which are neccesary drivers but i have already installed LabVIEW run time 2012
but still face the same problem
I am monitoring data from NI OPC server.
Message 4 of 11
(6,460 Views)
hi Tanya, Any specific error you getting ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 11
(6,444 Views)
there is no error, I can open the application normally but the problem is it not connect to my sensors from the platform
Message 6 of 11
(6,434 Views)
Add image little bit bigger so that we dont have to use microscop Smiley Very Happy
then this might be issue of any driver
--Ranjeet
Message 7 of 11
(6,422 Views)
Smiley Embarassed
hope microscope isn't neccessary now Smiley Wink
Message 8 of 11
(6,415 Views)
there are some ways to debug, add error indicators to your HMI, values/boolean indicators in some place of your code to see where it pass and where it doesn't.
Moreover the runtime labview may not be enough if you are using visa etc ... the best is to create an installer from your project with your exe (in labview 2013 it adds automatically the needed installer such as visa etc ...)
are you using comports etc ?
Message 9 of 11
(6,373 Views)
If you wrote the software, you should know exactly what drivers you are using - DAQmx, NI-VISA, etc.
Message 10 of 11
(6,367 Views)
