UI design
You can download DAQ example in which UI is also there. Also that depend on your and your user requirement
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 16
(1,479 Views)
      Thank you for  you advise. I understand the principle. But I want to carry on my UI  design according to a specific theme(like military, industry). Are there some documents or demo or control suite?
Message 12 of 16
(1,472 Views)
got that but actually there is no theme. All themes are modified as per your requirement
--Ranjeet
Message 13 of 16
(1,466 Views)
I have some personal guidelines:
1. Use SYSTEM controllers/indicators
2. Disable default right click menu. Make your own instead.
3. Make your own run time menu
4. Change graph background colour. (transparent?)
5. Change Window title. from main.vi to something that make sens
6. Have a sensible minimun panel size
7. Make it resizable
8. Do NOT use that modern red STOP button. Ref 1.
9. Hide toolbar when running
Im not saying that this is the blue print, but hopefully it will help you on your way.
Message 14 of 16
(1,460 Views)
Thank you. It will help a lot.
Message 15 of 16
(1,450 Views)
Oh, yes. Do you know good resources for DAQ example? I am a freshman, so maybe bother you to recommend some
Message 16 of 16
(1,449 Views)
