USB DRIVER FOR IMAQ
Sorry everything isn't in synch yet.  Now that you have the VIs installed for LV 8.2, if you just download the latest DLL in this thread, you will get Simplified Chinese support, along with all the other OSes we have added.  The EPD installer doesn't have the latest DLL, which I am working on updating, but for now, the procedure should be to run the installer from the EPD (which will give you LV 8.2 support), and then use the latest DLL from this discussion forum to get all the latest OS support.
Brad
Message 101 of 197
(4,139 Views)
Hello Brad,
 I would like to aks you to support for Traditional Chinese langulage OS too. I am attaching screen shots.
Brad
Message 102 of 197
(4,076 Views)
The screenshot you provided is not for simplified chinese, but for English, which is already in the driver.  Here's a copy of the latest DLL and if you're still having problems, it may be the camera driver is not Direct Show compliant.  Have you tried other USB cameras?
 Hope this helps,
Brad
Message 103 of 197
(4,043 Views)
How can I use USB Camera in LABVIEW8.2?
I had used USB Camera in LV8.0 after installing USB driver as we known very well.
I think this driver is not work in LV8.2. But Vision Assistant of LV8.2 showes image through USB Camera.
After install USB driver in LV8.2, I can't see function icon in function palette.
Warmshine
Message 104 of 197
(4,017 Views)
Hey Warmshine,
The latest installer has LV 8.2 support (assuming you have Vision installed with LV 8.2 support). Use the installer located here:
Make sure you have the llb installed (Program Files\National Instruments\LabVIEW 8.2\vi.lib\imaqUSB\imaqUSB.llb) and if so, make sure the vision7.mnu is located in Program Files\National Instruments\LabVIEW 8.2\menus\Categories\VisionMotion\ (It might be located under menus\default\Vision and if so copy it and put it under the Categories\VisionMotion\ location).  I will update this in the installer.
Brad
Message 105 of 197
(4,003 Views)
hey Brad,
I would really appreciate if you could make a fix for Turkish version.
I attached the error picture
Ragards.
Message 106 of 197
(3,964 Views)
Here's an updated DLL with Turkish support.  Let me know if you have any problems.
Brad
Message 107 of 197
(3,825 Views)
hi Brad,
It works fine now.
thanks a lot.
Message 108 of 197
(3,813 Views)
hi Brad,
a fix for german version would make my life much easier.
Thanks for your work in advance.
Error message is attached.
Best Regards, Thomas
Message Edited by tkuehnel@gmx.de on 07-27-2007 12:52 AM
Message Edited by tkuehnel@gmx.de on 07-27-2007 12:53 AM
Message 109 of 197
(3,525 Views)
That string is already in the driver.  Make sure the camera driver is installed correctly and if you call the enumerate NI-IMAQ for USB function, your camera is in the list.  Not all camera drivers are DirectShow filters and this is required for the NI-IMAQ for USB driver to recognize the camera. If your camera doesn't show up in the list and the driver is installed correctly, try a different web camera (I use "Creative" web cams without problems).
Hope that helps,
Brad
Message 110 of 197
(3,503 Views)
