USB DRIVER FOR IMAQ
hello brad,thanks for your help
帖子被han5578在06-26-2008 08:42 PM时编辑过了
Message 171 of 197
(5,413 Views)
    my system is XP SP2,simplified Chinese  OS and LV8.2,now the vision assistant works fine,but the program doesn’t work
I thank you in advance for you help.
Message 172 of 197
(5,413 Views)
han5578 -
It seems that you have not selected a camera. Be sure to use the IMAQ USB Init VI to initialize the session and identify a camera. Also, you could try using one of the USB examples, which should be installed ...Program Files\National Instruments\LabVIEW 8.2\examples\IMAQ\imaqUSB examples.llb
--Michelle
Message 173 of 197
(5,496 Views)
thank you very much,Michelle
now,my program works fine,it is the OS's issue
han5578
帖子被han5578在06-28-2008 09:22 PM时编辑过了
Message 174 of 197
(5,474 Views)
The latest installer has LV 8.2 support (assuming you have Vision installed with LV 8.2 support). Use the installer located here:
Make sure you have the llb installed (Program Files\National Instruments\LabVIEW 8.2\vi.lib\imaqUSB\imaqUSB.llb
 I´ve installed labview 8.0 then vision assistant 7.1 then installed the "imaq_usb_installer_setup.exe" but i can´t find the llb described above,and also can´t find any example on the examples of labview 8.0 folder for the imaq driver , so i really don´t have a clue of what im doing wrong if someone can help me with this.
Message 175 of 197
(5,116 Views)
Why I can't find it after I install it in LabVIEW8.6?
Boone301@126.com
Boone
Message 176 of 197
(5,072 Views)
Hello, I am using a Sumix 150M camera, which is not a web cam but an industrial USB camera who is said to be Directshow compatible. I have windows XP SP3 installed in French. I am able to acquire image (with Vision Assistant or the IMAQ USB VIs) with a regular webcam but not with the camera I want to use. Does this means that it is the direct show driver of the camera that is not working properly? Is there anything that can be done. Moreover, when I use the VI that lists the camera that are connected, it is the capture filter appears in the lists. So NI recognises the camera but won't acquire images from it. If there is nothing to do about the directshow driver not working properly, is their a procedure to acquire image from a USB camera that is not directshow compatible? Thanks for your inputs, VeroLat
Message 177 of 197
(4,800 Views)
There are some camera drivers that can have a camera enumerated but it doesn't mean the camera can be acquired from using DirectShow standard entry points to the camera DLL. I have even seem some camera drivers that have an item enumerated even when no camera is plugged in. It sounds like the IMAQ USB driver is installed correctly if other web cams work, but I don't think there's much we can do if your specific camera doesn't work.
Message 178 of 197
(4,734 Views)
Hi Brad,
I am using Sony Camcorder DCR-HC96E which has capacity to take pictures of 2048 X 1536.
But when I connect it through IEEE i-link cable and use USB Driver developed by Karissa Purcell; I can only able to acquire in 720 X 576 pixels only.
This is b'cos the image comming is in compressed format. Therefore is there any way out to acquire the image in original format of 2048 X 1536 by decompressing the signals.
Pl. help
Sandesh
Message 179 of 197
(4,695 Views)
Hello Brad
I use usb driver for imaq on simple chinese windows xp sp3.after download simple chinese dll ,It work very well but video/image property page window's title was not corrected,please fix it ,thanks
Message 180 of 197
(4,262 Views)
