USI 15.0.2
I am trying to build an installer in LabVIEW 2016 and I keep receiving a message saying the following installers are missing when I try to build the installer.
"LabVIEW 2016 Platform,
NI USI 15.0.2"
I've done some searching on the forum and have read that I need to navigate to the installer, which should be located in my install media.  The trouble is, I can't find it on the installed media anywhere.  I have a USB and DVDs with various installers and drivers on, but searching and browsing have so far failed.  Can someone please point me in the right direction?
Thanks in advance.
(5,312 Views)
Hi srankin16,
LabVIEW 2015 DataFinder Toolkit, DIAdem Version 9.0, LabWindows/CVI Version 8.1, DataFinder Server Edition 1.0 and LabVIEW Version 7.1, and later versions, use a shared software component (USI) that is updated when you install LabVIEW 2015 DataFinder Toolkit.
Therefore, I presume you can find the installer for that component in the NI LabVIEW DataFinder Toolkit that corresponds to your LabVIEW version.
Let us know your results. Regards,
(5,246 Views)
Accepted by srankin16
Thanks for the reply.
I actually managed to get it working (somehow).  I basically did a full re-install of LabVIEW with all the drivers, restarted my computer and then it worked.  It appears the missing file was saved on my PC once I did the install and it is now working as intended.
(5,242 Views)
That's good. Thank you for the update, srankin16.
The best of luck with your application!
(5,238 Views)
