 alex.
			alex.
			11-28-2008 04:20 AM
There are many vis named start with SIM in the dependence check as in the attached screenshot.
These vis are never been called or used.
But they are built into exe and make the exe size bigger.
Any suggestion. Thanks.
 Pnt
			Pnt
			11-28-2008 07:44 AM
You forgot the screenshot.
How they never been called, and they exist ?
Do you mean they are called only at development and not at the exe ?
11-30-2008 07:53 PM
 Pnt
			Pnt
			12-01-2008 12:23 AM
Check the hierarcy to see which vi is calling them.
Someone must call them... maybe a Labview-shipped vi
 dan_u
			dan_u
			12-01-2008 01:51 AM
This was discussed before. The possible solution is here: http://forums.lavag.org/missing-VIs-issue-t8601.html
The discussion on LAVA points to this KB article.
Hope this helps,
Daniel
12-01-2008 08:45 PM
May I know how to check the 'hierarcy'
And I tried both 'Repair' and 'Manual Repair' the toolkit, but seems not work yet, still a lot of SIM vis in the dependence.
Any suggestion?
(PS. Do you know any open source project for LV?)
 RavensFan
			RavensFan
			12-01-2008 08:56 PM
turbot wrote:May I know how to check the 'hierarcy'
View menu. Then View Hierarchy.
 Pnt
			Pnt
			12-02-2008 12:19 AM
"Do you know any open source project for LV?"
Any project ?
One is the Code capture tool.
12-02-2008 04:40 AM
I try to view hierarchy of several main vis, but still cannot find them(SIM). Any other ways to check, thanks a lot.
Where can join the Code capture tool, thanks.
12-02-2008 05:51 AM
Finally found a vi as attached, I am not sure if the Gmath or AALBase library inside caused the problem.
Should I change the default setting for build specs as attached, not use the last option.
