Unable to Run VI on Remote Machine Using VI Server
Hello!
I'm trying to run a VI on a remote machine using VI server but no luck. I used the "remote run VI" off from LV Inter. II. I've check and followed the VI server configuration. I also tried turning firewall on both PC but still nothing. Can't think of anything that stopping the VI to run on the remote PC. Any help will be appreciated. Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,738 Views)
Accepted by topic author KowdTek
Hi KowdTek,
Are you doing something like this?
Thank you for choosing National Instruments.
Aaron Pena
http://www.ni.com/support
(3,717 Views)
Hi Dr. Horrible.
Yes, it's very similar to your example. It's working now but not both ways and for some reason I can only "ping" my PC one way.
Can I just launch any VI created from the main PC or it has to be in the library? I asking because I tried launching a VI (simple VI) and it did not pop up to the remote PC.
Thanks for the quick response.
______________
KowdTek
LabVIEW 2009
(3,708 Views)
Figured, thanks!!!
______________
KowdTek
LabVIEW 2009
(3,703 Views)
