Unable to get Multichannel output in LABVIEW
i got your point but can you send me a pic or .vi file please
Message 11 of 19
(2,330 Views)
I tried but still face same problem
Message 12 of 19
(2,330 Views)
  • Run your VI until you get the error and the string shows in the indicator.
  • Stop the VI.
  • Select the string indicator and "menu...edit...make selected values default".
  • Save the VI under a new name and attach it again
  • Now we can actually try to reproduce your problem. (for example, we cannot tell if there are hidden characters from a picture).
Message 13 of 19
(2,324 Views)
can you find that where i make a mistake ?
still not getting a data using Spreadsheet String to array
Message 14 of 19
(2,323 Views)
You keep attaching useless pictures instead of the VI as instructed.
  • The format should be %d, not some long string.
  • We cannot tell what your "delimiter" is, but it does not look like an string containing a space only. (Still, these are not characters that even appear in your input string).
  • The type needs to be a 1D I32 array. (If you leave it blank, you get a 2D DBL array)
Message 15 of 19
(2,322 Views)
here is the both vi files
Message 16 of 19
(2,319 Views)
Sorry, I won't be near a computer for a while. Hopefully somebody else can look at it.
Message 17 of 19
(2,314 Views)
Just like altenbach said, for the Spreadsheet String to Array function, the delimiter should be a single space character, not the string "apostrophe space apostrophe" like you wired to it, and the format string should be just a single "%d", not three of them separated by spaces. You need to tell the function that a single space is what separates values, and that each individual value is formatted as a decimal integer, so that it can correctly parse your received string.
Also, if you have a choice in the matter I would recommend sending a termination character at the end of your sequence of numbers, so the VISA Read knows when to stop waiting, instead of timing out. The default, as you have it configured, is a linefeed character.
Message 18 of 19
(2,309 Views)
Hi pd,
every single item in the image is important:
Using a NULL byte as delimiter was a bad decision. It will give you headache when trying the same with other programming languages! Better use a comma, semicolon, or even a real SPACE…
Why did you try a delimiter of ' ' (including quotation marks) in your VI???
Is this really your "final year" homework?
Message 19 of 19
(2,293 Views)
