Unable to use USB-4432 along with DAQExpress
I am not able to use my data acquisition card USB-4432 along with the DAQExpress software.Is it so that the DAQExpress will support only the cards which can be mounted on a cDAQ chassis?
Please help me in resolving this problem
(2,028 Views)
I am noticing that the USB-4432 is listed as "Mature", which means it is on its way onto obsolescence.  So it is likely it was given any support in DAQExpress.  I do know DAQExpress works just fine with my USB-6212, so it is not just dependent on cDAQ.  You might want to give your local NI sales rep a call and see if they can help you find something else that will work for you.
(2,013 Views)
