Unchecking view as icon property
Can I check or uncheck view as icon property of multiple block diagram objects at once??
Labview user
(3,025 Views)
Accepted by Aojha
If you've tried to, you will already know the answer.Smiley Wink
Or there is a setting in Tools - Options - Block Diagram to 'place front panel terminals as icons' if that's what you are looking for.
(3,020 Views)
Yes, In LabVIEW 2012 you can select any number of terminals, right-click, and change them all at once.
(In LabVIEW 2011 and earlier you cannot do that)
(3,015 Views)
