Unexpected application error
I was going to try it but I'm using LV 7.0 and your source is 8.0.
  ...Dan
Message 11 of 21
(4,055 Views)
Yes it's LabVIEW and DSC 8.0...
Thanx anyway Dan!
But I don't think it's my code, because it worked well during 1 hour. I had the error when I closed LabVIEW and then I tried my code again and the error came back...
How weird...
Message 12 of 21
(4,053 Views)
Peachy,
I can't reproduce the crash either.  Everything in your VIs is standard and I have never seen this crash before.  Can you reproduce the same crash on another computer?
I also attached a modified version of the DSC Event Structure example VI.  This may be a more efficient way of displaying your alarms.  You can test the VI by simply adding it to your project and running it while your main panel is running.
Nick F
{Nick C July 13, 2006 10:28 a.m. CST-Edited Attachment}
Message Edited by Nick C on 07-13-2006 10:28 AM
Message 13 of 21
(4,039 Views)
Hi Nick,
I don't know either why I have this error. I didn't try on another computer because I don't have the DSC module install on it. We are suppose to receive the DSC module today or tomorrow so I'll try it on another computer.
Thanx for you help.. I really don't know what to do with that thing, that's weird...
Stephanie
Message Edited by Nick C on 07-13-2006 10:30 AM
Message 14 of 21
(4,037 Views)
Peachy,
  I'm sorry the other VI doesn't display the XControl correctly.  Here is an updated version:
Message 15 of 21
(4,025 Views)
Sorry again Nick,
But I can't run it because there are some files missing (LabVIEW is looking for files in an example in a newer version of LabVIEW)
Stephanie
Message Edited by Nick C on 07-13-2006 11:07 AM
Message 16 of 21
(4,024 Views)
Still not finding files Smiley Indifferent
Message 17 of 21
(4,024 Views)
Alright, sorry it's working
Thank you, I'll check what you did
Stephanie
Message 18 of 21
(4,021 Views)
Peachy,
  Ok.  Last try.  I have a bunch of modified copies of the examples on my computer.  (Even the last post will work, you just have to point it back to the correct example program folder.)
Message 19 of 21
(4,017 Views)
Hi Nick,
I looked at your code and it's working with no error (so, I guess the problem is in my code..!?).
It's not exactly what I want to do. I'd like to change your code but I don't really understand it. There's no information about the Format Alarm Data.vi so I don't know what it's doing exactly. Also, I have no idea what is a Refnum.
But thanx anyway, I hope I'll find what is the problem in my code.
Stephanie
Message 20 of 21
(4,003 Views)
