Unflatten From JSON
Although with this input I am able to have the correct output  :
 When  I try to write more to my JSON string i get this error  :
I have tried to change the timestamp and sensor_data types to arrays but it didn't work.
Lastly I would like to parse a JSON file which contains information just like this but i cannot make the function start unless I have a JSON string, which defeats the purpose of reading a JSON file altogether.
Kindly address both my problems.
Thank you in advance
Message 1 of 9
(3,234 Views)
What data type are you trying to get in the second case?
Message 2 of 9
(3,219 Views)
Thank you very much for trying to help me .
I will test your solution and come back to you.
In the second case I try to parse a Json file that contains this type of data :
        "timestamp": "2024-09-19 20:44:23",
        "sensor_data": "Waiting for command..."
        "timestamp": "2024-09-19 20:44:24",
        "sensor_data": "Sensor started."
        "sensor_data": "Soil Moisture Value is 0"
So that would be string and string
Message 3 of 9
(3,210 Views)
But what do you want to get?
only first cluster or array of clusters?
Message 4 of 9
(3,204 Views)
array of clusters
Message 5 of 9
(3,200 Views)
In this casetext has to be [{},{},{}], There are no square brackets in your string.
Message 6 of 9
(3,194 Views)
 when i dont have the brackets i get and invalid string form but when i have them i get a type missmatch
Message 7 of 9
(3,132 Views)
You need to wire an array of cluster for type
Message 8 of 9
(3,127 Views)
Now you format it as an array but asks it to unbundle a cluster ...
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(3,116 Views)
