Unique 3d rotation using the activeX 3d graph
Thanks altenbach ... that's very neat and tidy.
My actual implementation of this is a little neater than the file I submitted but it was the one I used to learn what the heck was goin on.  I thought it might be a little easier for people new to the ideas to follow what was goin on in my original version of it.
I never thought to use the event structure though ... that makes sense.  I'm glad that people are enjoying this code ... it definately took me a long time to figure out what was needed to be done.  Thanks again altenbach.
Greycat
Message 21 of 28
(1,419 Views)
Hi Greycat,
Could you save this as a 7.0 format so I could take a look?? Thanks
Message 22 of 28
(1,412 Views)
OK unclebump ... here it is ... I got a warning about "cannot save 3D Curve.vi to 7.0 format" ... or something like that.  So I don't know if it will work ... but the math should still be there ... here is my version
Greycat
Message 23 of 28
(1,401 Views)
and altenbachs revision ....
Message 24 of 28
(1,399 Views)
Greycat,
Just an added note: LabVIEW 8.0 will have a full set of 2D and 3D transformation tools. For example, you can easily do 3D rotations defined by a rotation matrix or by Euler angles.
Coordinate Transforms
  • Coordinate Shift
  • Coordinate Rotate
  • 3D Coordinate Conversion (Cartesian / Spherical / Cylindrical)
Things WILL get easier for all us! :D:D:D
Message 25 of 28
(1,396 Views)
I opened both version in LabVIEW 7.0 and they run fine. No errors. 🙂
Message 26 of 28
(1,392 Views)
That's great ... the only problem is I probably won't get to play with the full version of it though ... the company I work for just purchased their copy of 7.1  ... don't know if they will be up for coughin up the extra dough so soon ... but we'll seeSmiley Wink   Any idea as to when 8 will be available for purchase?
Greycat
Message 27 of 28
(1,393 Views)
Hello Greycat,
LabVIEW 8 will be shipping in November, and the add-on toolkits will be available later.
Shakhina P.
Applications Engineer
Message 28 of 28
(1,379 Views)
