Unsuccesful build installer: Upgraded product
I've been searching the forum for a solution for this.
I can't build an installer for our software since it keeps failing on an upgraded product. I get the following error:
The following product(s) are not found on the system or have been upgraded:
NI-DAQmx Application Development Support 18.5
Error 7 occurred at CDK_Utility_GenerateErrorCluster.vi -> CDK_Validate_DistParts_2010.vi
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
I tried updating the NI-DAQmx and Labview drivers. Got a "can't install version 18.5 since a newer version is already installed" once, but I think that's the problem? Why doesn't labview automatically update the version used in the builder? How can I manually do so?
(3,108 Views)
Accepted by DennisvdH
Hi Dennis,
In the Installer Properties dialog - check the "Additional Installers" page.
If it is not set to "Automatically select recommended installers", it may try to use a previously selected version.
The DAQmx version detected by the installer should match what shows up in MAX (My System -> Software).
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,075 Views)
Right, that got my through the process of building the installer. Now waiting on our IT department to test it on a clean device (that's where we had issues with certain drivers not being included in the installer). I'll update as soon as I've had a response.
(3,044 Views)
