Unsupported VIs for the cRIO-9030
I am fairly confident it is a bug. I forgot that I posted a similar problem in November. https://forums.ni.com/t5/LabVIEW/On-cRIO-9033-property-node-Owning-VI-Reference-is-Invalid/td-p/2990...
It seems like the linux rt's have a hard time handling references. This really limits what I can do with my UIs.
Message 11 of 15
(982 Views)
Hello LJHerskowitz,
Can you give a little bit of an overview of the program you are working with and how you are interfacing with the front panel?
Are you seeing a specific error?
Kelly B.
Message 12 of 15
(962 Views)
 Below is a very quick example of this error. I see a 1055 error; LabVIEW:  Object reference is invalid.. I thought I only saw it in a sub.vi which is why below has a sub.vi doing the same thing as the main vi. But both currently give me an error.
Message 13 of 15
(945 Views)
Hi LJHerskowitz,
I'm not sure if this is a bug yet, but I will be attempting to reproduce the error.
Which VI is the main VI referencing?  Is that VI located on a host PC or on the cRIO?
Kelly B.
Message 14 of 15
(924 Views)
Hi LJHerkowitz,
I believe the problem is occuring in the VI Front Panel property node.  I have submitted CAR #517922 for this issue.
Please let me know if you have any additional questions.
Kelly B.
Message 15 of 15
(906 Views)
