Upconvert VI Requests
Sorry muks, but could it be, that you accidentally attached the original version?
Message 101 of 1,261
(2,373 Views)
I mass compiled using 8.0.
Message 102 of 1,261
(2,358 Views)
O.k. but did you attach the compiled files? Because LabView still claims it to be 5.0. And if I look at the date of the files they are still from 1998 and 1999. Shouldn't they exhibit the current date?
Message 103 of 1,261
(2,351 Views)
Message 104 of 1,261
(2,328 Views)
Perfect, many thanks,
\Ulli.
Message 105 of 1,261
(2,320 Views)
The problem is that the files inside the zip are set to read-only. When mass-compiling LabVIEW will not save the VIs if the file is set to read-only. It will also not tell you that it can't save the files because they're read-only. The files you posted before had the same problem. I rad into the same issue when I couldn't understand why the files wouldn't open in LV 9 after compiling in 8.2, and then I looked and saw that the files were read-only, so I had to change that attribute.
Message Edited by smercurio_fc on 06-08-2010 09:20 AM
Message 106 of 1,261
(2,295 Views)
Didnt know that. Smiley Surprised
Message 107 of 1,261
(2,290 Views)
Looking for an upconvert from v5.0 to anything v6.0 or higher (running v9.0.1).
Thanks in advance!
- Joe
Message 108 of 1,261
(2,255 Views)
I got V12DLINX.dll missing error several times.
Message 109 of 1,261
(2,246 Views)
Thanks in advance!
- Joe
I had upconverted, but I saw that muks posted it. HOWEVER, the problem you're going to have with this is that the VIs use a CIN (which in and of itself is outdated technology), so you will need to reload the code resource. If you don't have that (it wasn't in the zip file), then the code won't work. You should go back to the manufacturer/distributor to find out if they have a new version.
Message 110 of 1,261
(2,242 Views)
