Upconvert VI Requests
@haehnel wrote:
i am looking to control an old spectrometer in my lab. I found labview VIs/LLBs from 2002. They are apparently written for LabView 5.0.1 . Could someone convert them to LabView 2009 SP1 for me?
I attached the files of interest. More may follow since they are not documented.
Thanks in advance,
Hendrik
Horrible, horrible, HORRIBLE code. Global variables everywhere! Yes, you're missing some subVIs.
Message 1081 of 1,261
(912 Views)
i´ve got a .llb, downloaded from TTi for an Power Suppply.
I´ve tried to convert the LabWindows .fp, also avaible from TTi for Download, but was not succsesfull.
Now I hope that somebody compiles the .llb.
best regards,
Heiko
Message 1082 of 1,261
(886 Views)
see here: http://forums.ni.com/t5/LabVIEW/Upconvert-VI-Requests/m-p/1711418#M604274
Message 1083 of 1,261
(880 Views)
i´ve thought, i could not be the only one, but haven´t found it.
Thanks a lot, now it is opening,
best Regards, Heiko
Message 1084 of 1,261
(876 Views)
can u convert this vi and llb to LV10?
Thank you.
Message 1085 of 1,261
(863 Views)
Thank you.
attached
Message 1086 of 1,261
(853 Views)
Can someone help to convert below file. Thanks.
source version labview 5.0
target version labview 8.5
Regards
Message 1087 of 1,261
(837 Views)
Can some one upconvert these labs to 8.0?
Thanks.
Bob
Message 1088 of 1,261
(830 Views)
Regards
Attached is in 8.2, which you can open. Not a whole lot to the VI, and a couple of functions can be deleted since the loop condition terminal can be set to continue or stop on condition.
Message 1089 of 1,261
(829 Views)
Thanks.
Bob
attached
Message 1090 of 1,261
(825 Views)
