Upconvert VI Requests
I apologize for bothering you again, smercurio. Attached are the .LLB files of the card KPCI-3102 drivers.
 Thanks so much.
Message 1051 of 1,261
(1,191 Views)
no attachments...
Message 1052 of 1,261
(1,183 Views)
Message 1053 of 1,261
(1,180 Views)
Well, we've got a bit of a problem with that library. Keithley used Code Interface Nodes. These need to be reloaded during an upconversion. Unless Keithley is willing to share these, then the library cannot be upconverted. You will need to go back to Keithley tech support and ask them to see if they can upconvert the code. Sorry.
Message 1054 of 1,261
(1,169 Views)
Hello everybody,
I want LabView 2010 to work with a HBM Spider 8. From HBM I got 2 LLB (I think LabView 4, should work with up to LabView 7.x), but I work with LabView 2010.
I copied the LLB to user.lib but I am not even able to open the VIs (to old).
Is anybody able to help me?
Thanks in advance.
Message 1055 of 1,261
(1,148 Views)
@seritz wrote:
Hello everybody,
Thanks in advance.
attached are the libraries in LV 10.
Message 1056 of 1,261
(1,143 Views)
Hi I need the same help.....please.....thanks a million....I have access to labview 8 and 8.5 but if you can save it in 8 that is better....any help will do.....it is originally a labview 4 llb actually i think.....hope thats not a problem
Message 1057 of 1,261
(1,132 Views)
I am unable to open the LLB. It may be corrupted. Or, it may be a bad upload. Try going back to the original file and re-upload it. Please put it into a ZIP archive to make the file smaller.
Message 1058 of 1,261
(1,122 Views)
Were you able to get the Spider 8 Running on LV2010? I have access to a LV7.xx Virtual Machine and will happily troubleshoot further for anybody who wants to work with 4.xx libraries on newer software.
Have a great day everyone!
Best,
Peter
Peter Rifken - Field Engineer & Business Manager
Boston / North New England & Maine
Message 1059 of 1,261
(1,089 Views)
Best,
Peter
Hello thanx the VIs are running fine with LV 2010, the are just some other (not LabView-) thinks i have to roubleshoot.
Message 1060 of 1,261
(1,086 Views)
