Upconvert VI Requests
Hi, Could you please convert these files from version 5.0.1 to LV 2011. Cheers, Rhys
Message 1071 of 1,261
(949 Views)
Hi Rhys,
where are "these files"?
Message 1072 of 1,261
(945 Views)
Apologies, i thought that i had attached them. Ill try again.
Message 1073 of 1,261
(942 Views)
Attached are in 8.2, which you can open.
Message 1074 of 1,261
(932 Views)
Brilliant, Thanks very much, i will try them out in the morning!
Message 1075 of 1,261
(930 Views)
Hi, I have this driver for LeCroy wavesurfer 44MXs. But this driver only work at 32-bit OS  and My windows 7 is 64-bit. The driver cannot work properly after installation. Pls help .
Thks.
Wilson
Message 1076 of 1,261
(924 Views)
Thks.
Wilson
You've already asked this question in this thread. As pointed out, your request makes no sense. You've provided no VIs to upconvert, or even a link to the files. Besides, upconversion does not change the "bitness" of a file. If the drivers are basically just wrapper VIs around a DLL that does not work under Windows 7 64-bit, there is nothing that we can do. You will need to go back to whoever made the VI to see if they have a 64-bit version. If they don't, then you will likely need to write the driver yourself.
Message 1077 of 1,261
(909 Views)
Good Afternoon All,
Could someone be so kind as to convert this .llb from LV 5.1 to 2010 for me please?  I have had it modified by the instrument vendor just for me and they apparently are behind in LV upgrades.  Not all the internal VIs are in 5.1 but some of them are and it is giving me a fit.
Thanks in advance,
Tony
Message 1078 of 1,261
(886 Views)
@loveac wrote:
Good Afternoon All,
Thanks in advance,
Tony
try the attached
Message 1079 of 1,261
(879 Views)
i am looking to control an old spectrometer in my lab. I found labview VIs/LLBs from 2002. They are apparently written for LabView 5.0.1 . Could someone convert them to LabView 2009 SP1 for me?
I attached the files of interest. More may follow since they are not documented.
Thanks in advance,
Hendrik
Message 1080 of 1,261
(873 Views)
