Upconvert VI Requests
@Djey89 wrote:
Hi smercurio_fc
Thanks for your reply.
OK. attached as 2009
Message 1161 of 1,261
(1,061 Views)
Hello!
I have some files compatible with Labview 4.0. Could you convert them to labview 8.5 compatible files? Thank you very much!
Message 1162 of 1,261
(1,057 Views)
@ihilali wrote:
Hello!
These have already been done in your post in the downconvert thread. Please read the response. You would have seen an attachment there.
Message 1163 of 1,261
(1,054 Views)
@smercurio_fc wrote:
@Djey89 wrote:
Hi smercurio_fc
thanks,
It does work now and these drivers are useful 😉
Djey89l
Message 1164 of 1,261
(1,048 Views)
please convert from lv 5.0.1 to lv 9.0
thanks.
Message 1165 of 1,261
(1,039 Views)
thanks.
Attached. Examples 3 and 7 have an interesting bug. See if you can find it. Smiley Wink
Also, the examples that use the DAQ VIs are using Traditional DAQ. You should use DAQmx.
Message 1166 of 1,261
(1,036 Views)
thank you for your interest.those drivers have been upconverted V4.0 to 8.5, but  I can't use them. The errors is being occured like attachment.
Message 1167 of 1,261
(1,025 Views)
I downloaded the zip file you attached to this message, and they are in 8.2. I am able to open them just fine in LabVIEW 8.2, which is what they are. Please make sure you are opening the correct files.
Message 1168 of 1,261
(1,010 Views)
Excuse me. I am uploading correct zip files. Thanks a lot from now.
Message 1169 of 1,261
(1,006 Views)
i think i should summarize the my problem. I am using LV 8.5. I have Adlink usbdaq-9100 instrument.  drivers of the instrument are for labview 4.0. There is no new files in  formal web site of it. When i run vi files of this instrument, the error message occured. The error message and files related to adlink usbdaq-9100 have been attached before. Shortly, if you solve my problem, i will glad.
Thanks for your replies
Message 1170 of 1,261
(993 Views)
