Upconvert VI Requests
@smercurio_fc wrote:
I had upconverted, but I saw that muks posted it. HOWEVER, the problem you're going to have with this is that the VIs use a CIN (which in and of itself is outdated technology), so you will need to reload the code resource. If you don't have that (it wasn't in the zip file), then the code won't work. You should go back to the manufacturer/distributor to find out if they have a new version.
Yeah, you're right, I do not have the lsb files to reload the code resources... CINs 😞
I guess it's on to Plan B.
Thanks for the help!
- Joe
Message 111 of 1,261
(2,153 Views)
Please help me with upconverting these 4 vi libraries to be compatible with LabView 9.0.1
Jang
Message 112 of 1,261
(2,135 Views)
Jang
Attached is in 8.2, which you should be able to open. I'm assuming yo have the ngcmod32 DLL.
Message 113 of 1,261
(2,129 Views)
Thank you very much.
I need to have three more libraries to be upconverted.
Thanks again,
Jang
Message 114 of 1,261
(2,116 Views)
Message 115 of 1,261
(2,097 Views)
Hello,i m new to LabView please let me knw how to connect /interact  animation in LabView to hardware??
Message 116 of 1,261
(2,098 Views)
This thread is for conversion. Post in the labVIEW board
Message 117 of 1,261
(2,093 Views)
Hi ,
please have this 5.0-libraries updated to 2009.
Thanks in advance!
Message 118 of 1,261
(2,051 Views)
Is this the same?
Anyway find the attached vis.
Message 119 of 1,261
(2,038 Views)
Hello, could someone help me to convert the attached library (5.1.1) to 8.5-version?
Thanks a lot!
Message 120 of 1,261
(2,014 Views)
